Jasons Thatcher buildlog
CX5
Taper jig
I cut and welded the jig to hold the spar caps to taper on the water jet cutter. The square tubes will be clamped to the cutter bed. The taper angle was built into the jig so I just move the nozzle on a straight x axis line.
CX5 Home
475
