Page 8-58 Installed the rod end bearings and jam nuts on the F-837-1 aft control mount. Mounted the F-837-A aft control mount in place in the fuselage Installed the rod end bearings and jam nuts on the F-849 forward control mount Attached the WD-807 control column to the rod end bearings on the F-849 forward control mount and the F-837-1 aft control mount Installed the WD-411 front control stick and rear control stick assembly on the WD-807 control column. Connected both ends of the F-839-2 pushrod assembly to the front and rear control sticks Installed the F-840 pushrod assembly Attached the F-635 bellcrank assembly to the aft end
