Page 8-57 Primed the inside and outside of the pushrod Threaded the rod end bearings and adjusted the overall dimension Constructed the F-840 push rod assembly. Installed rod end bearings on the F-840 pushrod assembly and adjusted the overall length Installed rod end bearings on the F-839-2 pushrod assembly and adjusted the overall length. Final drilled the 1/4 inch holes at both ends of the WD-807 control column Final drilled #12 the rod end bearing holes used to attach the control column to the F-849 forward control mount and F-837-1 aft control mount Final drilled #12 the holes used to attach the W-816 aileron pushrod assemblies Filed and shaped the bushings and filed the tubes that sleeve the bearings to size
