Page 8-58 Drilled the mounting hole in the WD-412B rear control stick Bolted the front and rear control stick in place on the control column and Adjusted the length of the F-839-2 pushrod to ensure the control sticks are parallel then locked the jam nut Removed the front and rear control sticks and installed the control column in the fuselage
