Page 8-56 Cut the F-841 pushrod to length Marked the rivet holes, inserted the VA-101 threaded rod end into both ends of the F-841 pushrod, Drilled #30 the eight rivet holes on each end of the pushrod Removed the ends, deburred all holes , re-installed the end and riveted into position.
