Craigs RV-8 Web Site
Date:  8-1-2011
Number of Hours:  3.00
Manual Reference:  8s8-1r1 12/02/08
Brief Description:  Seat Floors
page 8-47
Marked the location of the two bolt holes in the F-445 flap bearing block and final drilled the two bolt holes #10
Trimmed the F-445 flap bearing blocks
Fitted the F-445 flap bearing blocks to each end of the WD-806 flap actuator weldment and positioned it in the fuselage per detail D, drawing 77
Match drilled #12 the F-830-1 left seat floor, F-831-1 right seat floor and F-815C-L-1 and R-1 outboard seat rib angles using the fwd bolt holes in the F-445 flap bearing blocks
separated the five F-830B-1 floor stiffeners, smoothed and de-burred them
Clecoed the F-830B-1 floor stiffeners and F-80-5C-1 floor support angle to the F-829A-1 front seat floor
Installed the F-829A-1 front seat floor
Match drilled #19 the two screw holes common between the F-829A-1 front seat floor and the F-805C floor support angle and into the F-805D brackets
Unscrewed and removed the F-829A-1 front seat floor , de-burred the #19 holes
Drilled #40 the holes for mounting the nut plates to the F-805D brackets. De-burred the #40 holes and machine countersunk them for flush rivets
Riveted the nut plates to the F-805D brackets
Clecoed the bottom half of the F-832E-1 front seatback hinge to the F-829A-1 front seatback. Match drilled #30 the front seatback hinge.
Clecoed the F829B-R-1 right foot well inboard web and F-829D-R-1 right outboard web to the F-829C-R-1 right foot well recess. Repeated for the left side.
Final drill #40 the 3/32 holes common between the foot wells inboard , outboard webs and foot well recesses.
Clecoed the left and right foor well assemblies to the sides of the F-829A-1 front seat floor
Final drill #40 all 3/32 holes in the F-829A-1 front seat floor
disassembled all parts attached to the F-829A-1 front seat floor and de-burred all holes.
De-burred the F-837-1 aft control mount
Removed the WD-806 flap motor actuator weldment and the F-445 flap bearing blocks.
Unclecoed and removed the F-830-1 left seat floor, the F831-1 right seat floor the F-805F-1 spacers and the F-834-1 aft baggage floor
Drilling bearing blocks
Match drilling the seat floor
Machine countersinking for flush rivets
