Page 8-48 Clecoed together the F-830-1 left seat floor and the F-831-1 right seat floor using the holes common between them as shown in seat floors drawing 77. Separated the F-830DEF-1 floor stiffeners into two F-830D-1, two F-830E-1 and two F-830F-1 Smoothed and de-burred the floor stiffeners Cleco'ed the 3 F-830C-1 floor stiffeners in place on the F-830-1 Left seat floor and F-831-1 right seat floor. Cleco'ed the four F-830B-1 floor stiffeners in place on the F-830-1 left seat floor.
Page 8-49
Clecoed the F-830D-1 and F-830E-1 floor stiffener to the bottom of the F-830-1 and F-831-1 seat floors Removed the F-830B-1 stiffener common to the rear seatback hinge Clecoed the F-833D-1 rear seatback hinge into position on the F-830-1 left seat floor (Drawing 77) Match drilled #30 the 3/32 holes into the seatback hinge Removed the F-833D-1 rear seatback hinge from the F-830-1 and F-831-1 seat floors Final drilled #30 the 3-32 holes in the F-830-1 floor stiffener that is common with the holes that attach the F-833D-1 rear seatback hinge Final drill #30 the 3/32 holes in the two F-830F-1 floor stiffeners that are common with the holes that attach the F-833D-1 rear seatback hinge Clecoed the two F-830F-1 floor stiffeners in place on the F-830-1 and F-831-1 seat floor. Match drilled #40 the keeper rivet hole into the F-830F-1 floor stiffener using the hole in the F-831-1 right seat floor as a guide Final drilled the #40 the outboard most hole in booth F=830F-1 floor stiffener. Clecoed the F-833D-1 rear seatback hinge in place on the F-830-1 and F-831-1 Seat floors. Manufactured a shim from .025 aluminum sheet to place under the hinge common to the F-831-1 right seat floor and match drilled it to the rear seatback hinge #30.
