Craigs RV-8 Web Site
Date:  7-31-2011
Number of Hours:  3.00
Manual Reference:  8s8-1r1 1202/08
Brief Description:  Seat floors
Page 8-47
Final drilled #30 the 1/8 inch holes common between the attach plates and the rear baggage bulkhead.
Final drilled #30 the 1/8 holes in the F-834-1 aft baggage floor common with the F-830-1 left seat floor, F-831-1 right seat floor and the F-807 bulkhead assembly
Final drilled #30 the 1/8 holes common between the F-834-1 Aft baggage floor and the F-818-L-1 and R-1 baggage ribs and the F-888-L-1 and R-1 mid longerons
Final drilled #30 all of the 1/8 inch holes in the F-831-1 right seat floor and F-830-1 Left seat floor
Final drilled #12 the forward two holes for mounting the F-873-1 aft control mount
temporarily mounted the F-837-1 aft control mount
Match drilled #12 through the F-830-1 left seat floor and F-814C-L-1 inboard seat rib angle and the F-831-1 right seat floor and F-814C-R-1 inboard seat rib angle using the aft two mounting holes in the F-837-1 Aft control mount
Removed the F-837-1 Aft control mount.
Drilled #40 nut plate attach holes in the F-814C-R-1 left seat floor and F-814C-L-1 inboard seat angle and in the F-831-1 Right seat floor and F-814-R-1 inboard seat rib angle
batch drilling the baggage shelf
match drilling the floor
Drilling the holes for the nutplates
