Brief Description: drilled / dimpled fuel hole cover, worked gas line
I drilled out both wings and the fule filler hole covers for install. Will rivet after I test fit the tank and lines again. Also worked on gas lines for a while tring to plan for exactly where and how I'm going to run the lines. Cut holes in ribs for gas line path. I had some fittings that would work for the site guage. Can't seem to buy those $23 each bulkhead 90 AN tubeing to hose fittings. Will continue to think on that one. That's over $80 for 4 90 degree fittings. Geez.
