BRAD'S WEB SITE
Date:  2-14-2018
Number of Hours:  5.00
Brief Description:  Tapped bad threads, fabricated tank lines
The threads were badly damaged in the main tank where the aux fill line comes in. I scraped between the threads digging out material with a small pick first hoping to clear a path for the tap to follow. It was pretty bad. I wasn't sure if I was going to be able to do it, or if I'd have to take it to a shop and have them add material and then tap it again. Luckily I was able to get the tap started and it followed the existing lines. I went a little to deep and took out most of the taper but I think I'll still get a snug fit. It's going to rarely have fuel coming through since it's the aux tank transfer line only. also worked on other line routing and bending.
Tapping damaged threads
fuel lines in place
fuel lines in place
fuel and site guage lines
