Brief Description: Landing gear and a few more tabs
I finished a few more misc tabs I missed and worked on one side of the landing gear. It was pointed out to me that the stock gear leg config may not accept fat bush tires. So just in case I may get them one day, I slimmed down the width where the tire attaches. I cut the existing lower bent metal from the main gear tubing and then pried with a screw driver until it was free. This way I would be careful not to cut into the main tubing. Then I folded it up until I got the clearance I wanted and then welded it back together. I also began to look at what I need to do to fix the fact that my rear seat does not come close to lining up with the drilled and tapped tabs for attachment to the fuselage floor.
