Brief Description: Finished skylight, added gopro tabs and gussets
The skylight structure is now complete (except for the holes to be drilled for bolts.) I added little triangle gussets to the upright support tubes so that later I have the option to drill a hole in them and attach items such as dome lights, etc. I added 3 tabs to the roof for the options of attaching gopros. One center behind pilot/copilot, one centered in very rearl bulkhead roof, and on mid way from a side angle. And the most excition shot.....I welded a tab to the top of the tail section (to be trimmed, frinal shaped later.) Will provide a secure connection for the very small Gopro session that will mount there on occaision.
