DWG 43 WD-762-D1 RV7 DYNA 1 Engine mount install to firewal. Hosted the engine mounts with gear legs on then lined all holes up then Drilled holes through both with the 3/8" bits , Took off cleaned and deburred all holes then installed all bolts listed in DWG 46 and tourqued.
