Had to remove the gear legs, used a 19/64" bit to open up holes for the (2) 5/16" bolts then a 5/16" bit drilled & cleaned 5/16" holes in engine mount to legs, After a few hours in fitting etc. installed both AN 5-21 bolts, washers and MS 21045-5 all metal lock nuts
