WHILE I WAS READJUSTING THE LEFT PUSH ROD I DECIEDED TO TRY TO SEE IF I HAD ENOUGH THREADS LEFT ON THE PUSH ROD BEARINGS WHICH I WAS WONDERING ABOUT SO I LEFT THE AILERONS LOCKED IN TRAIL POSITION WITH THE AILERON PUSH RODS ON AND THEN I BACKED OFF THE LEFT AILERON PUSH ROD JAM NUTS THEN I TOOK THE PUSH ROD AND TURNED IT ALL THE WAY TOWARDS THE WING TIP. I WENT TO THE END AT THE CONTROL STICK AND THE AILERON PUSH ROD HAD COME OFF THE ROD BEARING. THIS IS A DEFINATE NO NO SO I CALLED KEN AT VAN'S AND HE SAID I PROBABLY CUT THE PUSH RODS TOO SHORT. I TOOK A MEASUREMENT WHILE IT WAS STILL IN AND I THINK I MEASURED IT CORRECTLY SO BACK TO THE DRAWING BOARD FOR THIS ONE.
