Christopher's Web Site
Date: 3-7-2017
Number of Hours: 3.00
Brief Description: Governor wiring, wire tying governor, swap fuel se
I seem to have an on-going punch list of outstanding squawk items. The current list included a few items identified on the first start-up. The first is the governor wiring.
The governor had a mind of it’s own and I know that a lot of people have been having an issue with this. Mine was sadly no different, however, I have an idea of some changes I can make, and we will see if it works.
The next item was truly securing the governor wiring harnesses inside the ship. I loosely secured them for the first run-up because I rightly assume that I would be back in there shortly messing with it.
The last item I repaired was something that I think goes back to the wiring diagram. Both Tom and I had the issue of reversed left and right fuel senders. I didn’t have any other wiring issues, and I find it too much of a coincidence that we both did the same thing incorrectly.
Luckily, the fix is simple when you know how it’s wired, so it was just swapping a few wires in the console. It probably doesn’t really matter since the tanks are self-leveling, but it bugs be just the same. If I know something is wrong, I’m going to want to at least try to fix it. I’m not sure if Tom has bothered with it at this point on his helicopter.
Govenor is the box behind the pan
