This is a really stiff cable. I have looked at a million photos of other Safari’s to determine where to best locate and run the starter wire. My manifold is not used on the older birds, so I only had a few to refer to for guidance.
I covered it in the protective plastic coil wrap, and I think it is run and supported very well, both inside the cabin, and adjacent to the engine.
The last wire to run was the jumper between the two lungs, and then install the boot on the main cable. The alternator is next.
