The repair is fixed and I will include the area in the fairing work. You will see the area of fairing widening as I get closer to the fished surface. I want it to be as perfect as possible, because this is a very visible component to the aircraft. As you can see, I have also begun working on the interior of the pod. More layers to follow…
