Top switch panel is now completed. I wanted it to look clean and without screws or rivets on the face of the panel where the switches and labels are going to be. I’m going to install nut plates on the inside of this panel, so the side screws are all that you will see.
I’ve just drilled a pilot hole where each of the clecos are installed on the console. I will need to drill an additional hole at each point, and in most cases as many of four more at each location that receives a nut plate. That will make more sense in the coming posts.
I have also drilled the post holes on the pod so I can see how it will fit on the console base. I’m happy with the fit and angle.
