BEZJet Build
Date:  1-7-2012
Brief Description:  Installed Brake Lines
Installed Brake Line Fittings and Hoses. Installed 2 MSC169 (90 Deg) fittings on the Brakes and 6 MSC168P (2 on the Master Cylinders and 4 on the Parking break valve). I also installed 2 MSC162P (Union), one on each side where the MSCNNR2/026 tubing comes out of the end of the Spar. This is so I can break the line at the bulkhead if needed.
I ordered Aeroshell MIL-PRF-5606H BRAKE FLUID from Aircraft Spruce. It Meets MIL-H-5606G and and MIL-PRF-5606H cleanliness requirements for aviation hydraulic oils. Has Superior low temperature properties and is Compatibility with synthetic rubber components. It is also Dyed red for easy identification and has Good anti-wear properties.
Brake Lines installed and routed to Master Cylinders
Brake lines routed to Parking Break
Break Lines Routed to Breaks
