BEZJet Build
Date:  12-28-2011
Brief Description:  Installed Emergency Blow down Valve
Installed the Emergency Blow Down Valve in Bottom Left of Instrument Panel. Tried to install it in the Left Console but it didn't fit well and would have been hard to reach. Drilled a 3/4" Hole in the Instrument Panel and fabricated an L Bracket to attach the Blow Down Valve. Then used 5 min Epoxy to bond bracket to back of panel.
Blow Down Valve Installed
Red Bracket Epoxyed in place
Valve Handle on Lower Left side of Instrument Panel
