Ran the Hydraulic Lines 1/4" Aluminum Tubing using Swagelok Fittings Per the Infinity Installation Manual. Installed the Up and Down Lines all the way to the Switching Valve and also installed the Lines to the Emergency Blow Down Valve. The Swagelok Fittings called out in the Infinity installation Manual for the Switching Valve were the wrong size.
Pump Up, Down and return Lines Installed
Emergency Blow down Valve installed
Up and Down Lines and fitting for Hyd psi transducer
