RV-7A Construction Log
RV-7A
Fuselage After Flip
11-29-2009
Forward Covers 11 Stick Boot Rings
Results of my first attempt shown below. Some how I didn't hold the plate square or something and some holes got to close to the edge.
So starting over with the larger covers, I drilled all the holes and edge margins are fine. I'll trim off excess as the last step.
Next I marked the hole size using the floor as the template. I drilled a big hole in the center
Make your covers 1/2 bigger
Bigger covers. 2nd attempt
Start hole to trim out center
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
