Marlins Web Site
RV-7A
Sec 7, Dwg 13A
Installing Aileron
I made a leveling jig using the tooling holes on the outboard rib chord line, Then used the belcrank jig to set the pushrod adjustment for "Aileron Neutral Position". Then I installed the bolts, nuts, washers and spacers.
Leveling jig using tooling holes
Tip of aileron on level (neutral) line
This bolt is a bugger to get in!
RV-7A Home
5827
Cockpit Upholstery
Constant Speed Prop
Cowling
Electrical System
86
1085
692
Engine Air-Baffles
362
Hangar
Hanger
Instrument Panel
IO360-M!B Engine
Ops Manuals
Pitot-Static System
Quickbuild fuselage
Shop, Supplies, and
Sliding Canopy
Wheel Pants/Fairings
Wheels
Wheels & Brakes
Windshield/Roll Bar
Workshop & Tools
