Brief Description: Sanded the wheel spats and fairings
The results after the first sanding are pretty good, after this I filled all the small holes where the clecos where holding things in place and also filled a few voids left after the sanding.
You can see in the photos the extra buildup behind the screw holes where the fairings attach to the wheel brackets to increase the strength in this area.
