Brief Description: Right Tank end rib and plumbing/wiring
Last thing was to do the continuity check for the capacitive system. Using the OHM meter, you check for no continutiy between the tank and the each plate - they should be isolated with no continuity (infinite resistance). And you also check for continuity between each plate and also each plate and the inner contact on the BNC connector. Both tanks checked out.
