Not a lot accomplished tonight. The sealant from last night has not set up yet. I connected and torqued the vent and return line connections. I also bent the end of the vent line up to the highest point in the tank I could get, and bent the fuel return line down to the lower portion of the tank.
For the wiring, I rotated the bushings to wrap the wire around the vent line. I then attached the two wires to the inboard plate with the screw and nut. Access is a little tight for doing this. Next step would be to goop up that connection, install the plate, and dab some sealant on the wire along the vent line to help secure it. But it was getting late so I called it a night.
