Brief Description: Wing Skeleton assembly and Drilling
I completed drilling the right wing. Disassembled each wing and de-burred the rib and spar holes. I dimpled the aft end of the outboard rib (W710?) to match the dimpled rear spar. I also dabbed a little alodine 1201 in the drilled holes in the front spar. Need to deal with the wiring provisions next.
