The last task of the day was to trace the larger fuel cap opening for the Rv-14 fuel cap rings for the left tank. This is the only “delta” work for using the RV-14 caps that I know of. Looks like a quarter inch or so that I need to remove. Once I get the hole sized, I can match drill and countersink.
Both sides drilled
This is what I need to trim for the RV-14 Fuel caps
