Daves Web Site
Date:  2-21-2009
Brief Description:  Aileron Attach Brackets Cont.
Today I riveted the pieces of each of the 4 aileron brackets together. Mounted a bearing between the 2 flange pieces and countersunk the holes that required flush rivet heads and set them on each of the 4 brackets. Next I riveted the pieces of angle aluminum that will attach the brackets to the wing. Finally I countersunk the holes (only one in each bracket attach angle) and set that rivet on each bracket. If that sounds confusing, you should have seen me trying to read the plans and determine the rivet call outs :)
The countersink tool (lover pic) and the countersunk hole (above the tool)
There are two flanges riveted together with the bearing (on the right) sandwiched between the two
Flush head rivet attaching the bracket to the wing.
