Daves Web Site
Date:  11-15-2010
Brief Description:  Landing Light - Right Wing (Part 1)
It's amazing how much easier and quicker it is to do something like this a second time. Marked the outline for the lens, used a step drill bit to bore the initial holes and then used tin snips to make the rough cut - then used the scotchbright wheel to finish the edges. Below is a picture of how to use the duct tape handle to pull the lens tightly to the inner leading edge of the wing for drilling. Nothing else different with this wing, just some different pictures. And again, I split this session into 2 entries to show additional pictures of this task.
Boring holes into the right wing leading edge
Rough cut, finished later with a scotchbright wheel
Pop's hand, holding the lens in place with a duct tape handle
