Daves Web Site
Date:  9-18-2010
Number of Hours:  3.00
Brief Description:  Bottom Left Wing Skin
Finally getting back in shop after a long period. Spent several days figuring out where I left off and where I needed to start next. Decided the next step would be to prepare the bottom wing skins. I also received the Safeair pitot mounting mast and the Dynon Pitot/AOA tube from Aircraft Spruce.
I started by removing the blue protective plastic along the area where the rivets will go. Next I temporarily attached the skin to the wing, match drilled the holes, moved the cleco's and match drilled the remaining holes.
Removed blue plastic from the rivet lines
Cleco'd Skin to the Wing
Dynon Heated Pitot/AOA Tube
