Daves Web Site
Date:  12-29-2008
Number of Hours:  4.00
Brief Description:  LH Elevator
Planned to go over to Allen's house tonight to let him approve the elevator trailing edge bend so I decided to go ahead and work on the LH elevator understructure. Cleco'd the spar, ribs, reinforcement plates, nut plates, counterweight and final drilled those holes. Then I attached the elevator skin to the understructure and final drilled all of the holes on both sides.
Went to Allen's and he said the trailing edges looked good so I will rivet the RH elevator and then disassemble, deburr, prep and prime the LH understructure.
Tip rib, counterweight rib and counterweight skin cleco'd together and to the spar
Opposite view showing the reinforcement plates and nut plates cleco'd in place.
Final drilling the skin after attaching it to the understructure.
