Notched the aft end of the ribs to fit around the splice and reinforcement angles. Plans showed the amount of material to remove. Used the band saw to make the rough cuts, a file to remove the blade marks, and the scotchbrite wheel to smooth out the edges.
Depiction from the plans on material to remove from the two ribs
