Daves Web Site
Date:  10-11-2008
Number of Hours:  7.00
Brief Description:  HS Front Spar
Started the horizontal stabilizer front spar assembly. Match drilled the holes for the spar channel and reinforcing angles. Tapered the ends of the reinforcing angles and bent them to 6 degrees per the plans. Trimmed the excess flange material off the 2 spar channels and drilled the relief holes. Polished all of those cuts up and bent the spar flanges to 6 degrees to match the reinforcing angles. Dimpled the 4 inboard holes on the spar flanges and tried to countersink the 4 holes in the reinforcement angles. Made one of the countersink holes too deep and ordered another reinforcement angle from Van's.
match drilling the reinforcement angles and the front spar
Drew the 6 degree angle on the table
Results after bending the reinforcement angles.
