After finally getting an acceptable fit to the cowling I began glassing the seam. I did two tapes thus far and will let this cure before adding two additional. I would have done it all at once except that the clecos holding my two halves together are in the areas which would be covered. I'll take them out once the initial tapes have cured then finish.
