Placed my master relay to the F/W. Really have to think about where things should go.
Will place my battery on the right side of the F/W. Still need to figure out the oil seperator and the cabin heat box.
Worked on the fuel tank a bit; shaved down the neck per instruction. I finally have all the pieces to plumb this thing. All fittings were cleaned and retapped as required.
Will need to clean tank; need more mineral spirits.
Placed felt on the tank straps and in the areas required by the plans.
