Cut the last remaining pushrod and installed them all. Rocker arms are torqued and Valves adjusted 0.006.
Installed valve covers.
Installed the end shims which were determined earlier. Oil seal tapped into place.
Oil screen placed and secured.
Had to wrap up the engine again to cut off additional studs which interfere with the intake manifolds. My Dremel died have way through so had to buy another. No safe way otherwise.
Installed both intakes.
The piece of angle visible in pic three is only so that I could turn the crank a bit easier.
