Jumped ahead as I was waiting for those new pushrods. Placed the Oil cooler bypass plate, fuel pump block off, dipstick. Removed the pre installed case studs so that the breather plate could be placed. No problem with a hot torch.
Will put the oil pressure sender in later. Also need to dril and tap the oil temp plate. Can not figure out what hole size it is; darn metric system.
Installed the prop lugs
Installed the oil pump per direction. It is well lubricated.
Ordered the oil cooler materials. I had considered not using an oil cooler as I doubt my environmental temperatures will demand it but.... I would like to be able to fly it outside at sometime and would need it then.
