Placed the voltage regulator and both ignition coils (for the secondary ignition). I then began to work on placing my gascolator. Yes I am using a gascolator. Despite Sonex and other vocal builders declarations to the contrary I do believe it is a necessary thing. I will work out the "burps" issue myself. It is difficult to find an appropriate placement that allows access to the curtis drain; the engine mount gets in the way. I decided to wait until I see the exact routing of my cockpit side fuel lines are placed. Alot of time doing nothing but thinking.
