Brief Description: Prep skins for deburr and dimple
I used a soldering iron to remove a strip from the rivet lines for deburring and dimpling. I tried making a loop in some copper wire to burn two lines at a time but it wasn't working very well. So I burned one line at a time.
It took some extra time to do this but I do like keeping as much protective cover on for as long as possible.
I prepped all the skins then I deburred and dimpled the bottom skin. I scrounged around the basement and found some scrap carpet and padding to make a couple padded supports out of a couple pieces of 2x10's.
