"I'm getting ready for the next riveting sequence. I spent a little time cleaning up the shop. I reinstalled the electrical conduit in the right wing. It was actually pretty easy to reinstall. In hind sight I should have done the same thing in the left wing.
One issue that we came across while riveting is when I drilled the holes on the skin overlaps the last hole next to the spar was located too close to the spar caps and we could not get a bucking bar on the rivet to set it. I was able to get a pop rivet in most of the holes so I took care of this today. When I originally laid out and drilled the holes I spaced them equally without taking into consideration of the spar. I should have allowed myself a little more room in that location."
