It's kind of fun to work the parallel piece of the opposite wing because it just kind of clicks and moves along after the first one. That was the case with the right flap. I finished up the left flap then moved on to the right. It went together very methodical. It was fun. No changes from the left flap - I followed the same sequence.
On his Bearhawk CD Russ really talked up using the pneumatic pop rivet setter. I took it hook line and sinker and bought one. Noting wrong with fortifying the tool box! This tool is well worth it! It made a very easy job of setting the nose skins.
I set the nose skins using the pneumatic setter. It's very slick and makes it's a very simple job. I'm already thinking my next project is going to be pop rivet construction!...
Flaps are done less the trailing edge which I’ll set when I fit to the wing.
