Waynes Bearhawks
Date:  4-15-2011
Number of Hours:  3.00
Brief Description:  Setting right wing flap
"I did a little more shop organizing then started on the right wing flap. First I pulled out all the hinges and bearings and refamiliarize myself with them. I found it easiest to line up the flap and aileron by pulling off the trailing edges.
I drilled and set the hinge mounts to the rear spar. I clamped the hinges to the flap and test for movement and there was no binding. I need to unclamp the flap again and make some adjustment forward and fit again. It looks like the top skin won't need anymore trimming but the bottom will.
It's nice to have a big table to work on."
Getting Parts Together
Lining Up The Trailing Edge
Flap Clamped For First Test Fit
