Brief Description: Aileron bellcranks, aileron support frame
I finished welding the flat stock on the other bellcrank. I then welded the cross brace on both pieces. Then I drilled the hole for the 5/16 tube for the aileron drive rod attachment and welded the tube on. There's a lot of work for these little parts!
After the bellcranks were done I finished welding the last end of the aileron support frame. This completes chapter 3 of Eric’s manual!
Now I'm getting ready to start chapter 4 - Assembly. I set the posts in position for the wing jig.
