I started making the parts for the root support frames. First I made the torque tube bearing just like on the flap support frame. Then I made the aileron cable support piece and then welded a plug into one end of the support tube. I carefully positioned everything together then welded together. Then I cut the tube to the proper length and welded the other plug in the end of the tube.
