Brief Description: Deburr left rear spar and drill rib attach angles
I finished deburring the left side parts, less the rib attach angles.
I spent some time studying and planning out the rib attach angles. I drilled a locator hole center line and 7/16 " from the end in the rib attach angles in the bottom of each piece on the side facing the spar. I then clecoed the angle to the capstrip at the hole location. Then turned the spar over and squared up the rib attach angle and clamped into place. Then turned the spar over and drilled the remaining holes.
Front side angles on the right spar are done and I started on the pocket rib attach angles. I'm spending some time on these to make sure I've got them positioned correctly.
