Brief Description: Deburr left capstrips, make rib attach angles
I deburred the left side capstrips. I cut 30 rib attach angle blanks out of 1-1/4" strips of .032. These are for the rear spar rib attach points for all but the pocket ribs. The pocket rib attach angles will be made from 1" strip material or as needed to locate pocket rib. I'll be using 5/8 x 5/8 rib attach angles on the main spars to accommodate the 5/32" rivet clearance, the rear spar rib attach angles are same size just to match the main spars. The extra clearance isn't needed for the rear spars. I bent the angles on the 18" brake and drilled the holes for the rib attachment.
