Brief Description: Rear spar capstrips and vertical stiffeners
I first finished up the table by screwing down 2 sheets of plywood. I cut all 8 rear spar capstrips to length and deburred the ends. I then cut out all the vertical stiffeners for the rear spar. I cut them on a metal chop saw. I deburred all the pieces on the 6" deburring wheel. I marked the center line on 4 of the capstrips. I then marked out the station locations, vertical stiffener locations, and all the rivet locations. That's a lot of marks. I center punched all the rivet locations in preparation for drilling.
Cutting Capstrips To Length
Marking Capstrips for Drilling Locations
Layout of Capstrips, Vertical Spacers and End Plate
