I'm getting to the point where I need to start priming parts. I'm using the method as outlined in Eric Newton's Manual. I cleaned the nose ribs with Acetone. I then buffed them out with scotch brite pads. Then they were washed with soap and water and rinsed. Then they were given a acid etching treatment with diluted Phosphoric acid. Then they were given an Alodine treatment.
